![]() | Home > Technical (L405) > Dry noise noise under acceleration - Diff problem? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
Hmm.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1039 ![]() ![]() ![]() |
I’ve just had the diff pinion seal replaced under warranty because it was leaking. Will keep my ears tuned for this noise! |
Dropped it off at MD this afternoon... good question NMJ... thought it important to take Stan’s advice and eliminate obvious causes before throwing the car at the mercy of the MD... still 3 hours of life that’s not coming back thanks to pfaffing around jacking wheels up, spinning them round, then taking them off and trying to eliminate causes... hey ho at least they got a good clean to the back of the inner rims... praying the MD doesn’t say they can’t find anything... or that they have found something and it’s not covered under the LR Extended Warranty |
Just had the health check video. LR technician says it needs a new rear diff. Waiting to find out if it’s covered under LR Extended Warranty...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35477 ![]() ![]() |
blimey, i bet you didnt expect that.... ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7851 ![]() ![]() ![]() |
Best practice to replace both shockers at the same time...... or maybe they will only suggest that if you are paying.... 2011 Range Rover Vogue SE 4.4 TDV8
I did expect it Stan tbh. Having had back to back RRs for a fair few years now you do get familiar with those expensive sounding “what’s that?” noises. Although, usually turn to the forum first to seek views of trusted forum members in the hope of eliminating obvious simple things first.
mJD is correct, however I Wouldn’t worry too much, they did just the one on my 322 and it was absolutely fine!
