Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
If you have the original 4 hoses then definitely ditch and replace with the 70mm silicone versions. Could be the source of all your issues. We’ve seen this a lot over the years and as Greg said, splits are often hidden.
9th Aug 2020 12:23pm |
9th Aug 2020 12:29pm |
paulparry82 Member Since: 04 Mar 2020 Location: Merseyside Posts: 21 |
It was a little sooty around the hard plastic spigot where the rubber hose mounts over. Didn't seem drastically sooted, but there was definite cake around the little raised bits etc. It's a process of elimination! |
9th Aug 2020 12:33pm |
The GAP IID Bluetooth is much better than the icarsoft lr2. I can say that as I’ve had both
9th Aug 2020 12:36pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
See my thread here. https://www.fullfatrr.com/forum/topic55878.html
9th Aug 2020 12:40pm |
Thanks DrRob, will be investing in the IID tool, and the ability to have it plugged in whilst driving without it covering my break peddle is much safer
9th Aug 2020 1:18pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Paul,
10th Aug 2020 8:12pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Close, it's Greg Also: use cruise control . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
10th Aug 2020 8:33pm |
Greg, sorry chap. It was late and I'd had a number of Beavertown Lupoloid beers!! Will update you as soon as I have stg concrete to report. |
10th Aug 2020 9:30pm |
Thanks Range Rover L322, and a good bit of insight / motivation to keep going with the investigation. I am definitely keen to rule out the 90% likely leak issue (and with a bit of luck that is what's causing this). I've got it booked in to a local garage today, I'm going to ask specifically for a high pressure smoke test on the air system.
11th Aug 2020 7:41am |
Good. If they only have low pressure then it won't be good enough to find the smallest leaks.
11th Aug 2020 7:53am |
Hi DrRob, sorry for the late reply. I've ordered the hoses to replace so when they arrrive I'll fit (probably over the weekend).
13th Aug 2020 12:26pm |
Have you had the high pressure smoke test done yet? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Aug 2020 12:45pm |
Not yet - the garage I took it to couldn't do the test so I'm going to have to find one who can. |
13th Aug 2020 1:04pm |
