Home > Technical (L322) > DPF failure to regenerate - AGAIN!! (AND AGAIN!! UPDATE) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
MJ Fews got any space for you?
18th Jun 2020 12:49pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3142 |
Mj Fews are the ones who can’t do it until July! Have got someone to look at it tomoro so we’ll see what he comes up with. |
18th Jun 2020 2:23pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Hi
20th Jun 2020 9:53am |
took it to an indie who looked and couldn't find anything really obvious. however he did say the parameters hadn't been re-set from when the sensor and inlet manifold was changed 1400 miles ago. He thinks it may have been the ECU being confused by too many incorrect readings and not allowing a regeneration to take place.
20th Jun 2020 3:41pm |
What did he do to reset it and could you have done it with your IID? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
20th Jun 2020 6:25pm |
No the IID tool couldn't (or I didn't have the skills/knowedlge) reset it. He said he re-set the parameters (not sure which). He used a (Matrix? I think) machine to read codes and check readings etc.
21st Jun 2020 7:18pm |
Did this cure it? Hope so Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Jul 2020 7:36am |
Hi Rob, only had a couple if journeys since the reset, but on the 2 x 50 mile motorway trips this week it has performed 100%. In fact although the soot level went up to 9.6g, it did a passive regen down to 8.4 at one point. I haven’t checked the figures since yesterday but will do today and report back.
3rd Jul 2020 8:25am |
25th Jul 2020 1:04pm |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 53 |
56700 demanded regens in 3 week is about 1 every 30 seconds!!
25th Jul 2020 1:25pm |
56,000 was over longer than 3 weeks
25th Jul 2020 1:35pm |
So, took her into Dick Lovett at Melksham for an fault find examination on Friday. They admitted they had never seen this before and They found no fault codes and so they did a PCM update and a test drive but failed to find a solution. Fault still there! bizarrely they then suggested that the only thing they could do (as the computer had run out of ideas?) was to do the updated (v2) Turbo Oil drain for several hundred pounds. I asked how that was going to solve a DPF problem as 1. My vehicle didn't smoke and already had the first fix done satisfactorily, and 2. This wasn't relevant to my fault so Why would I pay all that money?
8th Aug 2020 11:20pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
Have you spoken with Steve @ T & S Norman, just past Shepton Mallet?. visiting from www.rrsport.co.uk |
9th Aug 2020 6:27am |
Hi getting old. No I haven’t - will do Monday. Thanks for the tip . Why do you recommend him? What’s his particular edge? |
9th Aug 2020 7:36am |
