Home > Technical (L405) > Small rear seat not folding
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
stan wrote:
ebay has these for around £40 upwards...although the part number ends in 'AA' and not 'AB'..
yes great, not sure what aa or ab means and if the part would work...
does anyone know ?
according to ebay looks it for diesel 4.4 only... 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #563668 5th Aug 2020 11:26am
karba78
i am afraid i am going to have to replace the connectors from the male plug. they are also rusted, anyone knows where i could find them
female, most likely 2 or 2.5mm wide 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #563670 5th Aug 2020 11:58am
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
This breaker has a used 'AB' from a 5.0 Jag XJ for £100
https://www.ebay.ie/itm/JAGUAR-XJ-X351-REA...3752230912 2017 SDV8 Autobiography
Post #563671 5th Aug 2020 12:07pm
karba78
million thks recordman, thats my part Bow down Thumbs Up
just ordered it
now need to find the female connectors that goes into the male plug. they are completely destroyed by rust 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #563672 5th Aug 2020 12:12pm
karba78
while cleaning the connector, i found 2 cut wires
the brown ones
i believe they should as in the picture attached
1) is anyone able to confirm wiring or where i could find the wiring scheme, to make sure i put them back at their place
but it does not represent the plugs, or i am too stupid to understand
2) does anyone know where to find a replacment for the male plug, believe is 2x7 flat 2.8mm, searched ebay found the connectors themselves but not the plastic enclosure
i found
14 purple
11 thin black
12 brown red (i think)
10 black
8 black
6 brown red ( i think)
1999 TD5 Defender
Post #563691 5th Aug 2020 1:47pm
karba78
found them
https://fr.rs-online.com/web/p/connecteurs-automobiles/1647187/
and
https://fr.rs-online.com/web/p/accessoires...e/9097356/
for those interested 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #563704 5th Aug 2020 4:42pm
recordman
just ordered it
Delighted to have been of assistance. Hopefully the part, along with the other connectors that you've located will fix the problem 2017 SDV8 Autobiography
Post #563705 5th Aug 2020 4:52pm
karba78
will keep you posted on progress, Smile once i receive the electronic unit, and the connectors, fingers crossed Smile 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #563744 6th Aug 2020 6:19am
karba78
so ..
received the part this morning
i remade the connectors earlier this week
plugged the new box and...
the seat commands for the passenger works perfectly; and i can also fold it completely from the passenger command on the right bottom part off the seat
BUT
the command from the trunk does not produce results yet... i can hear the relays but its not commanding the seat...
still searching if anyone has an idea
thks all for getting there 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #564274 12th Aug 2020 7:52am
Mikeerhymes
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Re: Small rear seat not folding
Brightondefender wrote:
Hello Very Happy
I have electric rear seats in my L405 and the smaller one of the 2 won’t move via the motor. When I flick the button you can hear a sort of electrical engaging but it doesn’t shift the seat at all.
Has anyone experienced this? Also does anyone know where the motor is for the rear seats?
Many thanks and happy Christmas 🎄
What was the issue in the end? Or was the main dealer update the way to go?
Cheers
Post #691898 4th May 2024 1:58pm
Foxie
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
New to Ownership... Just three days in now.
After 10yrs and 140k miles of L200 Barbie ownership, something comfortable was required to pull the toy to events.
Somewhat used to dealing with Electrickery Issues after AlfaRomeo147GTA ownership; Then SmartBrabus Roadster Ownership...
But: Where is the seat module located ????
I've had both rear seat pads out, along with The whole boot stripped...
Can I see the module.. Can I 'eck !!
Near Side rear passenger seat doesn't move at all and the positioning/lumbar controls don't operate at All... Off-side rear operates fully as intended.
If someone could provide an idiot-Proof Location for the module, that would be proper appreciated..
Post #695663 6th Jul 2024 4:55pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I'm not sure what car you have, but there is a module in the spare wheel area on the left side after you remove the lining. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #695680 7th Jul 2024 7:09am
Foxie
Thank You TT.
I'll check that out.
2013 SDV8 4.4 Santorini AB
Post #695726 7th Jul 2024 9:55pm
Foxie
Finally had chance to have a look...
I can't find the whereabouts of the rear LH module as suggested.
Finally discovered idiot-proof description of it location.
The LH/near-side seat will not fold down from the rear boot controls or adjust from the side seat controls. Merely looking for the module to check electrical contacts etc.
Found this... For anyone else looking for info.
https://static.nhtsa.gov/odi/tsbs/2015/SB-10105913-9430.pdf
Turn's out there is no module in place what-so-ever!! Shocked Shocked
That'll be why the seat is inoperable!!! Rolling Eyes Rolling Eyes
Now into the throws of new module and programming in.. 2014 SDV8 4.4 Santorini AB
Lamborghini C305S
Hanix H36A
Hanix RT300
Post #697101 29th Jul 2024 7:40pm
Mikeerhymes
Hello Very Happy
Cheers
Annoying but easy fix in the end for me, looking under the seat I could see a disconnected cable. The car had the fuel tank replaced by the MD, I suspect they didn’t put the seat connections back correctly after removing….
Post #697232 1st Aug 2024 2:11pm
