Home > Technical (L322) > Td6 egr delete ?
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Td6 egr delete ?
Hey folks just asking on my td6 i can blank the egr or do a full removal ? If i were to remove it all including the cooler what do i do with the water pipe that feeds onto that small black thermostat thingy on top of the egr cooler as the thermostat thingy is leaking any way around one of the 10mm bolts that holds it to the egr cooler do i just blank that water feed pipe too thanks folks
Post #563322 1st Aug 2020 9:01pm
from our wiki,
https://www.fullfatrr.com/gallery/thumbnails.php?album=339 ... - .- -.
Post #563323 1st Aug 2020 9:03pm
Johnsd1v8
Top man stan have you done yours ifso what did you do with the thermostat pipes from the cooler
Post #563324 1st Aug 2020 9:19pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I saw these bungs a while ago but cant work out how they fit. From memory i think a 15mm cap with a jubilee clip has been used by others.
https://www.aliexpress.com/item/4000647990...5392%23958 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #563335 2nd Aug 2020 10:52am
all that needs to be fitted is one of these,
a few threads re this,
https://www.fullfatrr.com/forum/search.php...rch_time=0 ... - .- -.
Post #563338 2nd Aug 2020 11:45am
The easiest way do an egr delete is to fit what Stan suggests above and leave all the egr cooler gubbins in place.
To guarantee there is no water circulation through the egr cooler thermostat you need to undo the top right water connection and slide a piece of 12mm threaded stainless steel rod or a cut off bolt about 20mm long into the exposed end of the plastic egr thermostat and refit the pipe. The 12mm insert is a good push fit with a couple of rounds of ptfe tape round it and can't dislodge as the water flow holds it in place. This results in no water flow through the egr thermostat what ever it's operating condition.
A bit of bodge I know but a good one that works and saves all the work in removing the egr cooler etc. Thumbs Up
You can remove the egr cooler gubbins at a later date when you come to replace the engine thermostat. Very Happy
Post #563340 2nd Aug 2020 12:09pm
