![]() | Home > Technical (L322) > 4.4 TDV8 won't start - low fuel pressure fault code |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Unless only just changed, I would change the fuel filter although it sounds as though the fuel pressure could be too high. |
rick293 Member Since: 27 Jul 2020 Location: Ballymena, NI Posts: 5 ![]() ![]() ![]() |
Changed the fuel filter tonight and put some neat injector cleaner into the new filter. No difference. Long crank time to a reluctant start at 500rpm idle on live data.
I don't have any specs on the 4.4 TDV8 but the 3.0 TDV6 has up to 29000 psi / 2000 bar. |
Last night I cracked an injector pipe while cranking. No diesel.
Can you get any fuel out of the low pressure pump in the engine bay? |
Is this at the outlet at the fuel filter? If I turn ignition on and push in the bleed valve diesel will come out. |
