Home > Technical (L322) > Strange thing happened the other day.. |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I unlocked the car using my wifes key and the drivers seat and mirrors adjusted themselves. I then used my key and the seat returned back to it's previous setting.
8th May 2009 10:04am |
82 views and no-one knows why? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
15th May 2009 4:24pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1090 |
I have never figured out why and when and how this is suposed to work. Button 1 is my wifes setting button 2 is mine each set with our own key, trouble is the car seems to have turrets and dos random things for the hell of it. letters not necessarily in the right order |
15th May 2009 6:07pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Mine did it once in the last year and the rest of the time total altzhimers on the hole idea, mind you every time I ask the stealer to turn a programable function on they turn more off, I told you before shuldn't be allowed near sharp objects. 2008 MY Supercharged
15th May 2009 11:20pm |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 278 |
Not sure about your MY, but with mine (and my D3 before that) you need to try the following:
16th May 2009 9:57pm |
EFA Yep tried that, I recon the seats were made from the hides of catle with mad cow disease letters not necessarily in the right order |
17th May 2009 4:40pm |
Point 7 above should read Memory 1, as per my post.
17th May 2009 8:49pm |
If all else fails read the manual, I shal play with it today letters not necessarily in the right order |
18th May 2009 7:08am |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 |
Aha, thanks for that, I will try....
18th May 2009 7:45am |
SHMBO=she who must be obayed 2008 MY Supercharged
18th May 2009 8:35am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6363 |
I know what the manual states it SHOULD do etc but I've always had the impression the key takes the settings from the last time it was in use. That's why for example, the CD disc playing is different when I swap keys, it remembers what I was listening to last time on that key.
18th May 2009 10:15am |
