![]() | Home > Technical (L322) > How often do fault codes appear? |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
I reckon that an existing fault will show up every time you fire up the car.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Probably one or more of the wires out of top of shocks are broken
Simmoto Member Since: 17 Jan 2020 Location: Scotland Posts: 48 ![]() ![]() ![]() |
Thanks for the replies, good to know so it's intermittent I've looked at the wires at the front, no breaks, drivers side is upgraded and other side looked fine but I removed and soldered in new wires on passenger side, took it for a drive and so far so good. Possible a passenger wire was broken inside the insulation I guess. Inspected rears and they look fine. Will probably replace both front ones. Could certainly do with IID tool but spent too much recently |
