![]() | Home > Maintenance & Mods (L322) > Reset All Defect Codes |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
If the indicated fault has been caused by battery disconnected/flat issues then you need to run the engine & turn the steering from full lock to full lock a couple of times. 2003 Range Rover Vogue TD6 |
ricky25 Member Since: 18 Dec 2018 Location: Leicester Posts: 17 ![]() ![]() ![]() |
Thank you. I've tried that a few times but it doesn't seem to work for me ! Thus, I was trying to do a fault code reset - which also doesn't seem to work for me ! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
You can't reset a fault code without fixing the fault, it will just come back..!! Pete
I think the error code results from a period of low battery voltage which has since been rectified. |
