Home > In Car Electronics (L322) > Invalid Disc Error - Clarion CD Changer and hitting it. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
if the tapping isnt helping then it could be the unit is faulty with a broken laser... ... - .- -.
20th Jul 2020 8:54am |
MarkinNantwich Member Since: 15 Jul 2020 Location: nantwich Posts: 42 |
I would try a cleaning kit 1st rather than beating it.
20th Jul 2020 9:00am |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Hi Stan,
20th Jul 2020 9:27am |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
This informative video might help.
20th Jul 2020 9:33am |
Love it and yes you might be right |
20th Jul 2020 9:47am |
i see your point Mark..
20th Jul 2020 10:17am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
It's a cd player....the laser will require cleaning you can use meths on a cotton bud or leather stick. |
20th Jul 2020 10:45am |
Stan- so true.
20th Jul 2020 12:44pm |
There are vids on YouTube CD mechanisms are nearly all the same |
20th Jul 2020 1:22pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 766 |
I can't remember the last time I used a CD in a car, I think it was loading some music onto the HDD in my 2009 5 series.
20th Jul 2020 1:45pm |
Well I started life as a Walkman repair engineer and have a life time of experience in fixing everything else including cd players , tv and video, audio and radio plus much much more I dont want to bore you with.
20th Jul 2020 2:14pm |
Thanks guys, I appreciate all the input. I'm going to start by using a compressed air hose at my local garage this morning and give it a blast, if that doesn't work then will consider Dave's advice on dismantling and cleaning, and finally if that doesn't work either a replacement or a swap out.
21st Jul 2020 7:30am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
As Dave has mentioned, cleaning with a cotton bud is the best way to go. Take the unit out and open it up. The lens is easy to spot. I've cleaned a few in my time with a bit of alcohol cleaner on a cotton bud, gently wipe it over the lens, allow to evaporate and use the dry end of the cotton bud to polish the lens after. No need to press down hard, just gently wipe the surface. 2011 TDV8 Vogue SE |
21st Jul 2020 7:38am |
Thanks Dennij. |
21st Jul 2020 7:41am |
