![]() | Home > Maintenance & Mods (L322) > No/Minimal Heating |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
When my 322s had heating problems they were cured by replacing the final stage resistor and lubricating the flaps that control where the hot air goes, I didn't do the work so can't offer more than that, sorry. Only Range Rovers since 1988 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Wot CS Said. Its normally the flaps sticking. Try removing the pollen filter and have a look. Mine worked after I refitted the pollen filter. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
I've had my 2003 L322 for nearly 5 years and have often complained about the lack of heat into the cabin.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I’m sure it was fine before. However, I have only had it on full cold ac for a while now.
Finally found time to look deeper into this today.
Where is this valve? Ron B. VK2OTC
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Can you add a photo of the valve & where it is in the engine bay. |
All the information I found was for the 3.6 tdv8.
