Home > In Car Electronics (L322) > Bovee/Tune2Air WMA1000 - Music Plays Only Briefly
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
WMA1000 via the factory iPod lead - connects fine, my iPhone is visible on the screen under Devices, and I can select a track to play from Spotify, but it will only play for a split second. I downloaded a track from iTunes to my phone to check, and that’s the same.
Doesn’t make any difference if my phone is also connected to the car’s Bluetooth or not - any idea what might be wrong?
Post #561614 15th Jul 2020 6:55pm
It is possible to update the software on the WMA1000. Might be worth checking to see if you have the latest and most up to date version.
Depending which one you have (even though they are the same not 100% the firmware is interchangeable)
The instructions for the update for the tune2air is here
http://www.viseeo.com/ImgViseeo/20141105162914.pdf There is nothing that can't be fixed with a hammer😜😜
Post #561626 15th Jul 2020 8:45pm
Philip
Thanks, I’ll see if I can find an old iPod cable. Has anyone else had an issue with getting music to play?
Post #561655 16th Jul 2020 6:49am
Philip
OK - it has now decided to work, but it won’t pause or stop playing; if I pause Spotify, a second later it starts playing again, and if I close Spotify it just starts playing the single iTunes downloaded track on my phone, even if Apple Music isn’t open - and pausing/stopping that doesn’t work either.
Any ideas?
Post #561701 16th Jul 2020 12:42pm
