![]() | Home > For Sale & Wanted > NOW SOLD |
Thegingerone Member Since: 21 Jun 2020 Location: South Wales Posts: 22 ![]() ![]() ![]() |
I’ve tried attaching pics to the advert but for some reason they haven’t appeared, not sure what I’m doing wrong |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
as you dont qualify for posting a for sale , did you purchase an ad? ... - .- -.
I did Stan
it doesnt show...
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 954 ![]() ![]() ![]() |
You should see what the autobiography part brought on the spec sheet is, as I believe the rear entertainment was standard on the se ? although I am sure someone on here will know for sure , but like you say autobiography’s are a rarer thank most but the options are vast I think, so knowing why it’s an autobiography would be a good sales point for yiu. |
Hi Andy, yes good point, problem is I don’t actually know what was additional on top of the vogue SE spec, this is the build sheet sent directly from LRUK
i am no expert but there are a lot of very knowledgable chaps on here...... having looked at the list i am not sure there's that much? do the rear seats recline (comfort seats) as thats an extra if they do.....
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
I think the towbar prep means that the car has the wiring loom plug in the rear right bay (next to the rear fusebox), into which the towbar loom and ECU plugs into. My 4.2SC was like that and I just fitted the towbar and loom/ECU over from my old TDV8.
Door Handles-Body Colour
Thanks for the replies guys |
So does that mean on the tow bar front it literally just the elect are there or is the truth with the receiver for the hitch there too (the metal bits with the big square hole in it 😀) so you just have to get the tow ball etc to complete?
The non-towbar towing eye and bracket on the left side need to be replaced by the towbar weldment, which uses the same four bolts but also bolts onto the rear crash bar. ---------------------------------------
Had a quick look underneath, no sign of any towbar, multiplug is offside rear quarter....
