Home > Technical (L322) > Another gearbox question / issue
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Recently my TD6 has developed an annoying (and probably expensive) issue when pulling away.
When left overnight, the first time i put it in drive it takes a lot of revs and a bit of a delay before it will move. If I select reverse its fine.
Only does it when it's left 12+ hours, driving is fine after the initial pull away and if left in D at a junction / lights it is pushing against the brakes wanting to go.
Box oil and filter were changed with the correct oil a few months back and the level is fine, has been ok up until about a month ago. No fault codes either.
Any clues on what to look at / test next?
Post #561356 14th Jul 2020 6:56am
