Home > Technical (L322) > Engine Oil Temp Sensor Problem - stumped..........
_Dan_
Hi All,
I have a DTC for 'Engine Oil Temperature Sensor Circuit Range/Performance' (P1096) on my 2007 TDV8 L322.
Diagnostic tool shows engine oil temp at -40degC (default value I presume)
I checked the resistance of the sensor in the sump - it appears to be in the correct range.
Replacing it with a brand new sensor makes no difference
I also checked the wiring diagram and continuity checked the wires from the engine controller down to the temp sensor - no problems there....
No sure what else to check, is there anything else that can cause these symptoms? Only other thing I can think of is an ECU issue, which I really hope it's not!
Cheers,
Dan
Post #476886 27th Apr 2018 8:12am
Cquadphil
Northern Ireland 2007 Range Rover Vogue SE TDV8 Java Black
Hi Dan, I have the same problem, did you get yours sorted.
Philip
Post #561227 13th Jul 2020 10:21am
