Home > Technical (L405) > Fault Codes on L405 19MY |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
That's a lot of faults but being relistic it's very unlikely your car has any genuine faults at all . Is the battery the original and has the car been standing idle for long periods without being on a trickle charger such as a ctek ?
11th Jul 2020 10:59am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
As above, you only need to try and start a RR with a low battery and all hell will be let loose in the form of a million fault codes... So, for the split second the car is trying to start with a low battery, all of those fault codes will be relevant... Once the car starts and charges, all of those codes will be a false indication of problems...
11th Jul 2020 11:11am |
Craig : Would a Autel have the updates for the 2018 onward range updates installed |
11th Jul 2020 11:24am |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
Thank you both for taking the time to reply.
11th Jul 2020 11:50am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Hi Mark, I’ve just bought an Autel MD806 pro and it only covers up to 2016! Hope that helps. Dave. |
11th Jul 2020 1:46pm |
Thanks Dave , when you connect your autel to your wifi does it not offer updates ?
11th Jul 2020 1:53pm |
Hi Charlie, yes it does, but they’re only for up-to 2016 so far. It may well work for certain features on later models but I’ve not tried it so couldn’t say. |
11th Jul 2020 2:07pm |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 467 |
From Pat on the GAP tool...
11th Jul 2020 2:53pm |
