![]() | Home > Technical (L322) > Auxiliary power for SDD |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
For the equivalent use case I thought the GAP folk recommend the CTEK MXS-10 charger for that, which has a "supply" mode to give a nice clean power feed.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
or another battery on jumps ?
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
I tried a ctek mcs-7 which also has a supply mode but that didnt seem to work. Perhaps i need to leave the battery plugged in for longer before supply mode is effective?
I haven't checked the draw with all systems running but no engine started, but I suspect it's quite possibly more than 7 amps, so maybe the MXS-7 can't quite cope with the load, and voltage does still drop?
Many thanks, i’ll get hold of an mxs-10 to try. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Yes, mxs10 in supply mode for a clean supply |
Excellent thanks DrRob - I had hoped the MXS7 had enough output but I guess not so I have an MXS10 on the way and will return the 7. I'm fairly sure I have towing electrics but need to investigate which type as I've never looked at it properly.
Thanks, that looks interesting. Do you use that as a battery support or more for charging? I’d need an AGM version though. |
Yes body ground, not the negative terminal ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Cheers! |
