![]() | Home > Technical (L405) > Rear door issue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
i'd be tempted to take the door card off and see if there are any loose connections or maybe water ingress.. ... - .- -.
1. Have you tried to see if all 4 windows open and close by depressing and holding the unlock/ lock button on the remote keyfob?
m11rphy Member Since: 12 Mar 2018 Location: UK Posts: 13 ![]() |
Yes, all 4 of our windows will open fully and close fully by depressing key fob buttons.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Ryan, if you go into your CCF files using your IID, switch on super locking single press... This negates the need to press the lock button twice to "super lock" the car... ![]() |
Thanks Craig |
Yes it is Martin... |
The wiring plug for that door is literally just where the loom goes into the pillar... if you open the plug and check the connections are clean etc etc ![]() |
