Home > Maintenance & Mods (L322) > Cleaning grime off the plastic top part of doorcard |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7825 |
Vanish foam and an electric toothbrush..... or a manual one if you are in to exercising.
7th Jul 2020 8:08pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Flash Magic Sponge (be gentle) .
7th Jul 2020 8:13pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
+1 What Joe said - but do it wet - with an all purpose cleaner
7th Jul 2020 8:20pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Cif and a nail brush with a bit of water. Comes up like new. |
7th Jul 2020 8:42pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Thanks chaps I am going to dismantle the doorcard to get the armrest off for reconolising while it’s off I will start with cif and tooth brush followed by the magic eraser Current stable:
7th Jul 2020 9:13pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I have recently cleaned the door cards on my old SL Merc, 21 years of ingrained grime. After trying various methods I found a steam cleaner to be the most effective and efficient method with excellent results
7th Jul 2020 11:30pm |
Thanks I have a little karcher steam cleaner do you aim the steam straight at the dirt and then scrub or do you have one of the cloths on it and scrub with that? Current stable:
8th Jul 2020 8:49am |
My steamer has a brush attachment that I used. Once the steam works its magic the grime lifted and could be wiped off with a microfibre cloth. 2007 TDV8 VSE
8th Jul 2020 8:59am |
Ok I went in guns blazing... started up with steamer and fairy on a tooth brush came out quite well and wiped down, then went cif gently rubbing in with a toothbrush let it soak scrubbed and came out really well. Passenger looks and feels like new , driver looks like new but has a slightly rubbery feel now? Any ideas? I also got a bit of furniture clinic on the handle not perfect but loads better!
21st Sep 2020 9:40pm |
