Home > Technical (L322) > 3.6 TDV8 - cracked driver's side manifold
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Sorry to hear you've been through this too Stuart. Seems a lot of TDV8 owners have...
I will report back how i get on with a repair. If it weren't for the poor access i'd be replacing the manifold in a heartbeat. 2008/58 FFRR 3.6 TDV8 Vogue
Post #550435 15th Apr 2020 7:10pm
jonminns
3,000 miles later i can report that the 291i is holding strong. I roughed up a large area with 80 grit paper, and cleaned meticulously with degreaser then IPA solvent. Applied the sealant in 2 goes, quite thick and worked it in as best i could. I applied a large area - around the size of my hand to cover a small crack so that probably helped.
In the end i didn't use the sika primer/activator. 2008/58 FFRR 3.6 TDV8 Vogue
Post #560368 6th Jul 2020 11:14am
