Home > Maintenance & Mods (L322) > Bottle Jack - Now sorted, thanks.
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Apologies for this, I know it's been done pretty much to death but bear with me. As a newcomer to the world of the FFRR I have no idea how high a jack needs to lift the vehicle to get a wheel off the ground.
Would this one do it or would I need to carry a block of (thick) wood around too?:
https://www.sgs-engineering.com/bj5s-5-ton...-with-case
It lifts to 413 mm.
Thanks,
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #560238 4th Jul 2020 6:45pm
DrRob
Is this for roadside wheel changes?
If yes, get a LR red “two horned” one. Works a treat and the horns add a level of stability. 2 pumps and wheel is clear of road to change wheel. Position under the lower arms, front or rear. Chock the diagonal one as usual Thumbs Up
Day 1, I threw the scissor jack (aka The Widow Maker) into the shed and chucked the red horned one under the boot floor Thumbs Up
Like this: https://www.ebay.co.uk/c/645348843 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560239 4th Jul 2020 6:52pm
DrRob
For driveway and other more meaty jobs then a trolley jack is needed. I have an SGS one with a sill adaptor
https://www.sgs-engineering.com/tj3-garage-3-ton-trolley-jack
Post #560240 4th Jul 2020 6:58pm
RRDunc
I have a 2.5 tonne SGS trolley jack for my D2, that'll do for the Rangie too.
I just want a reasonably priced substitute jack to replace the infamous scissor jack.
Post #560255 4th Jul 2020 8:58pm
DrRob
See my first post above for replacement for scissor jack. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560275 5th Jul 2020 7:30am
Or a Mercedes sprinted jack modded with a cill adapter is what a lot use. There are threads on here on how to do it. There is nothing that can't be fixed with a hammer😜😜
Post #560281 5th Jul 2020 8:44am
DrRob
No mods needed for red LR jack and you don’t have to fight the air suspension 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560300 5th Jul 2020 1:55pm
RRDunc
Indeed. Thank you Thumbs Up
Dunc The life you have is the only one you'll get; make the most of it.
Post #560320 5th Jul 2020 5:14pm
