Home > Technical (L322) > Thinking of Converting 4.4LV8 (M62) to 3.0L TD6 (M57D30) - |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7809 |
There are loads of bits different, but figured engine and gearbox were enough to allow a good idea/bad idea decision. 2011 Range Rover Vogue SE 4.4 TDV8
4th Jul 2020 3:04pm |
I’d look for a cheap TD6 donar car to make sure you have everything you need, and also act as a reference point for you.
4th Jul 2020 3:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8252 |
Just my 2P
4th Jul 2020 7:47pm |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
Get a junkyard M62, do the timing guides, PCV, cam cover gaskets, fit and enjoy. Or just get a TDV8. |
4th Jul 2020 10:32pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
buy yourself a cheap tdv8, and sell the v8 non runner. the only thing you can change over, in reality, is the FFRR sticker in the rear window. TDV8's are real value these days, as diesel is falling out of favour. and they have some power, and economy.. find one with a couple of appearance issues, and work on that. changing engines, looms, programming ecu's, security, becm, is a nightmare. -spannering in a lump, might be the easy bit. coding it to run, is a minefield.
4th Jul 2020 10:57pm |
