Home > Technical (L322) > Thinking of Converting 4.4LV8 (M62) to 3.0L TD6 (M57D30) - |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
Different motor, different gearbox, different electronics.
4th Jul 2020 6:38am |
Samuel Member Since: 04 Jul 2020 Location: London Posts: 6 |
Different Motor - Ofcourse
4th Jul 2020 8:00am |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 |
I thought the td6 had a gm box, which was at best made of cheese and was not long term durable? |
4th Jul 2020 8:07am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Put another decent V8 in....simples! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
4th Jul 2020 8:15am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7809 |
It’s absolutely not the same gearbox, the TD6 uses a GM gearbox and it’s very much a weak point as the valve body is made from softer aluminium.
4th Jul 2020 8:21am |
These specialists may be able to assist with general questions....
4th Jul 2020 8:41am |
The TD6 also has the fuel burning heater fitted as standard to help the engine warm up. Hardly any V8 petrols had that.
4th Jul 2020 8:49am |
@mjdronfield - Will connect with birchmotors and check with them.
4th Jul 2020 9:05am |
I don’t have any info, just that I know it was derived from the 4.4 V8...... would probably be a pain to do.
4th Jul 2020 9:40am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
how about a V12 conversion?
4th Jul 2020 10:56am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Deffo +1 for a V12 transplant
4th Jul 2020 11:13am |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Covering petrol to diesel would be a mission. S62 from an m5 would be better or a 4.6 from an X5? Similar engine and the 4.6 has had alpina fettling.
4th Jul 2020 11:53am |
Thank you all for Very tempting suggestions. I definitely lost direction for sometime. However, I will stick to TD6 conversion for sanity sake. Need the conversion to be cost effective. |
4th Jul 2020 1:20pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
Excuse my reservations about this, but if you are going to do this engine swap for 'cost effective' reasons, wouldnt you be better trying to get hold of another petrol V8? Surely its going to be cheaper overall than trying to put in a Diesel and all the different ancilliaries?
4th Jul 2020 1:34pm |
