Home > Technical (L322) > Amber DPF Full - Increase in Oil Level |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
I'd not worry about it too much if the Amber has now gone after a run. It was probably near it's limit when you had it idling on the drive and the run out cleared it. The owners manual states the recommended speed and duration needed to clear the amber. Revving the off it is not needed.
3rd Jul 2020 7:13am |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Jul 2020 7:16am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
John,
3rd Jul 2020 7:23am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Just to clarify, it’s the fuel/oil dilution Reading we are all talking about, not the engine oil level. If it is making your oil reading increase by that much I am surprised. Best get a fuel dilution reading on your new IID ASAP as it may point to something else causing it.
3rd Jul 2020 8:37am |
I'll also add that the oil level indicator is not always 100% accurate. When you take a reading make sure to leave it for 30 seconds to stabilise. Sometimes mine adds another notch after, sometimes it doesn't. Dipstick was best!
3rd Jul 2020 8:45am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
You definitely don't need sport mode or revs.
3rd Jul 2020 9:10am |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 |
Many thanks to every one for your replies.
3rd Jul 2020 4:26pm |
Lovely scenery
3rd Jul 2020 4:41pm |
