Home > Technical (L322) > Remote driver utility module.
RREIRE
Ireland 2007 Range Rover Vogue SE TDV8 Java Black
Hi Folks,
I have a Range Rover L322 3.6 TDV8. I have an electrical gremlin. It will drive for a week or more. Then Bing Bong.... Censored Censored . Gearbox fault, Hand brake fault, suspension fault. Engine is going to explode.......you get the picture. Twisted Evil. I have plugged it in. It saying Remote Driver Utility Module. I can't find it anywhere. would anyone know where this is?. It got a new battery and alternator. i have checked all connections under the bonnet. it driving me mad. I can come out to the car the next day and it will be fine. I am just about the get rid off it. I have put so much into this car. I can't keep it if it's going to be so unreliable. Hope someone can help me. Thanks in advance.
Post #559402 28th Jun 2020 5:04pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Strangely enough my GAP IID arrived today and I had a play. After clearing all the faults -33- took it for a run, used every button and driving mode etc. Re-tested and this was the only fault remaining. Another forum gives-
'Every US spec RR will have this fault.
The driver utility module is another name for the companion camera, which was not available in this country, but now I see you're not in this country.
Either way, unless you're having issues with your wireless camera, this fault is not relevant at all.'
I haven't got a companion, just an occasional carer!
Hope this helps
Post #559713 1st Jul 2020 1:31am
RREIRE
Thanks.😊👍. I have ordered new batteries for both my venture cams. I hope the new batteries is all they need. Thumbs Up
Post #560251 4th Jul 2020 9:37pm
stuart_2006
Can I ask which batteries and where from please? Need to replace them in my camera as well.
Post #560343 5th Jul 2020 11:17pm
