![]() | Home > Technical (L322) > A/C and rear blowers auto starting. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Ref the rear aircon switch, no you can’t do anything. It always comes in automatic and you have to wait 5 secs before manually switching it off.
grey17 Member Since: 31 Aug 2018 Location: ha6 Posts: 65 ![]() ![]() ![]() |
Hi Dolphinboy.
Hhhmm not sure why that is. I would echo those with the knowledge on This forum who all recommend you have the aircon on at all times as it not only stops the seals drying out, but also removes water vapour from the air inside the car. |
Neilacker Member Since: 02 Mar 2020 Location: Haydock island Posts: 21 ![]() ![]() |
Mine did this for years until I replaced the battery, after that it would remember the settings I left it on when switching car off, hope that helps 2010 tdv8 vogue se, Buckingham Blue |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
I’ve never turned my air con off after I got a £700 bill 20 years ago.... keeps the rubber seals lubricated and stops the windows steaming up.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I keep the rear blower dial set to off.
