Home > Maintenance & Mods (L322) > FFrange rover roof to screen Body coloured roof rail trim.
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
hi im trying to locate the trim on the roof in the rail what meets the windscreen . i just wish people changing screens did their job correctly and not bodge it .
they must have broken the trim clips but used putty to hold it in place.
the motorwat soon put that to the test .
Baltic Blue required . both sides
Can they be sourced from a dealer and are they colout coded or would this be a rpaint job after buying .
Andy
Post #559310 27th Jun 2020 10:33pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
You mean the weatherstrip in the roof rail? Comes primed new or sure you can find second hand from a breakers.
Right DBC000022LML
Left DBC000032LML
Trim Clip DBE000011
Clip LR014488 Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #559330 28th Jun 2020 8:38am
Landyandy1765
Many many thanks
Do you know if it's the complete strip you buy or the front part .
Andy
Post #559386 28th Jun 2020 2:10pm
I might be wrong but I think the front piece is held on with a couple of trim clips, which break when you remove them, ask Robin at Duckworths to check... Thumbs Up Pete
Post #559409 28th Jun 2020 4:51pm
They break when you take them out.
One from a breakers will not sit right. You might be able to get the clips from Robin, but if they’ve knackered the strip then it’s a new one which will need painting...... the monkeys at Longleat pulled one of mine off one time and snapped it. While new stripe required, and some painting..... There is nothing that can't be fixed with a hammer😜😜
Post #559412 28th Jun 2020 4:59pm
So the Northern Monkey went to see his relatives in the south... did you upset them... Rolling with laughter Pete
Post #559414 28th Jun 2020 5:04pm
Must have.....
Cost me a few quids to sort it all out.
Not been to see them since There is nothing that can't be fixed with a hammer😜😜
Post #559415 28th Jun 2020 5:07pm
Landyandy1765
im pretty sure they used monkeys to change the windscreen . lol there was a glob of dumdum left in the roof rail when they departed .
thanks guys for the info . i will get them ordered this week .
also i will use the misses discovery when visiting the Safari park
Post #559437 28th Jun 2020 9:09pm
Bingo_123
Could anyone confirm that the white clip LR014488 goes into the body and the black clip DBE000011 goes onto the trim and then upon pressing the trim, they both lock in place.
i am facing this problem and the trim has come loose on the driver side. when i checked, i only found a white clip on the body with a screw in it. Tried to press the trim onto this white clip but it wont hold, so that makes me believe that i am missing the black one which goes on the trip.
Please confirm, TIA
Post #676308 24th Oct 2023 2:26pm
