Home > Technical (L322) > No communication with various modules
Shane48
United Kingdom 2002 Range Rover Vogue Td6 Barolo Black
New owner to range rovers with my first issue Rolling Eyes I have suspension inactive on dash. When plugged into diagnostics I have no communication to the BCU, air bag module or the air suspension module. I have a fault code stored in the ABS module for air suspension CAN error 138. Had a quick look and fuses all ok have good powers and earths to the air suspension module, BCU is working but for some reason not picking up on diagnostics. From what I can see all these modules are on the K BUS with exception of air suspension which is on K BUS and also connects to ABS module via the CAN bus. Any ideas on where to go next.
Post #559296 27th Jun 2020 8:49pm
You could do worse than buy one of these devices from eBay, item number eBay Item No. 183379533939.
I'm pretty certain it will solve your problems and is a very useful item to carry in the car.
Post #559297 27th Jun 2020 8:57pm
Shane48
Unfortunately that won’t help as I cannot connect to the EAS module to reset anything, and I do already have a diagnostic tool which should be upto the task
Post #559299 27th Jun 2020 9:00pm
I have a similar problem re connecting to diagnostics but for some reason this device connected directly to the eas and abs without any problems, read the faults and cleared them in about a minute. Thumbs Up
Post #559301 27th Jun 2020 9:04pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Any water in the front left foot well?
Check the ECU behind the left kick plate forward of the door take a look inside for corrosion
Post #559315 28th Jun 2020 3:34am
Shane48
No water from what I can see, also module was unplugged wheni looked
Post #559316 28th Jun 2020 5:33am
RR P38
What happened when you plugged it in? If you did
Why was it unplugged?
P0138 is 02 sensor issue
Post #559318 28th Jun 2020 6:27am
Shane48
Still no communication, I never unplugged it was done by a previous owner by the looks of it. The fault code isn’t p0138 it’s just ‘138’
Post #559322 28th Jun 2020 7:00am
