![]() | Home > Maintenance & Mods (L322) > Red parking brake light flashes sometimes |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Mine does it occasionally, usually when on a steepish slope. My guess is the car detects movement which exceeds a set threshold or force on the gearbox. Ie it thinks the handbrake isn't doing its job properly. 2016 Skoda Octavia VRS Estate
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4324 ![]() ![]() ![]() |
Ditto on steep slopes. I wonder if it’s to make you use the footbrake as an extra precaution |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 ![]() ![]() ![]() |
Ditto on our driveway in Poole, which is reasonably steep - happens to me maybe 20-30% of the time there when starting, but only ever had it there and nowhere else! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8380 ![]() ![]() ![]() |
I wonder if it's the brake fluid level, I believe it's the same light to warn you if it's low, on a steep hill maybe it's enough to put the low fluid light on..!! Pete
