![]() | Home > Technical (L322) > Warning lights |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Its unlikely to be a fault with the park brake itself so my guess is either an ABS sensor or the steering angle sensor is the cause. If either an ABS sensor or the steering angle sensor is considered unreliable then the emergency function of the park brake won't be available and therefore the park brake will show a warning rather than faulty.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Im afraid your a little stuck without diagnostics sir... |
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Craig
Absolutely sir... Just not on this occasion... 👍 |
