Home > Technical (L322) > 2008 SC curled up it's little toes and died, help?
d00d
2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Bit of a story to tell here, please bear with me... Big Cry
So I had the tranny go out on my NAS 2008 SC last year and replaced it, (after trying a rebuilt mechatronic first, which I kept in the "new" tranny), but after a few months had worsening hesitation/slippage/whatever in gears 3 and/or 4 which has been getting worse and does genuinely seem like the replacement tranny is failing as well.
However...
As I was troubleshooting/confirming that a few weeks ago, I read an article where somebody had similar symptoms and it turned out to be a power problem.
Alternator (still) seemed fine then but the battery was old so I replaced it but it made no difference. Then I started getting real transmission errors at the console a couple days ago and figured it was just the tranny being unhappy because of the slippage.
But just to be sure I used my IID tool to pull the diagnostics to see if there was anything useful, and saw all the errors below, which I assumed to be related to my changing the battery. But I did a video just to be on the safe side, cleared them all so I could get a fresh set of diags for the next round of errors and kept driving it.
Of course I got a few more errors but before I took the time to run diags again the engine cut out without warning as I was getting onto the freeway. I also got tons of warning lights flashing and bells ringing and a stream of errors across the console.
I coasted to the end of the onramp where it was wider, hopped out with my multi-meter thinking maybe I'd neglected to tighten a battery clamp or the alternator really had died or something, but battery voltage at rest was 12.2v, clamps and cables seemed fine, so just for the heck of it I tried the key and it started right up! Lots of warnings and flashing lights for everything and such still of course, but the engine was running! For about 2sec, then it stopped again, but I tried again, revved it a bit and then it stayed running and seemed to idle fine and things seemed okay aside from all the alerts.
At this point I had also plugged in the IID again and could see the alternator putting out 14.2v. I didn't take the time to pull the codes then (dammit!) as I was running late for a meeting.
So then...
After the meeting I came out and tried to run diags, but the IID tool is very picky and, among other things requires the engine to be running. Turning the key enabled all the lights and warnings but nothing at all happened when I tried to start the engine, not even a relay click. So I left it an hour or two, tried again, still nothing. I disconnected the battery for 20min or so, reconnected and tried again, still nothing. Quite literally a case of, "lights are on but nobody's home!"
That's when we towed it... a-a-and the mechanic says none of their diagnostic tools will even recognize that the CAN bus is present! I get the feeling "something" is choking the CAN, (and maybe even causing my original tranny issues?)
Looking for thoughts on getting the IID tool to work w/engine off, and how to troubleshoot the CAN bus, e.g. what can I disconnect to get it to the simplest operational state?
For what it's worth, this is exactly what I got from the diags last weekend, (transcribed from the video I took).
Power and random misc are probably from the battery swap, but the comm errors are interesting:
AAM - Audio Amplifier
B1A02-13(2F) Speaker 2 circuit
B1A01-13(2F) Speaker 1 circuit
ACM - Audio System
U1A03-62(2B) Vehicle configuration parameter
BPM - Body Processor
0x0040re Unknown
FLM - Headlamp
B1D66-00(28) Left headlamp power module
B1D67-00(28) Right headlamp power module
U3000-16(28) Control module
U0122-86(28) Lost communication with vehicle dynamics control module
IPC - Instrument Pack
U2016-41(2F) Control module main software
U0248-87(2F) Lost communication with remote driver utility
LCM - Light Control
0x005Are Unknown
0x005Fre Unknown
0x007Are Unknown
0x007Bre Unknown
PAM - Parking Aid
0x0001re Unknown
0x0002re Unknown
0x0003re Unknown
0x0004re Unknown
0x0005re Unknown
0x0006re Unknown
0x0007re Unknown
0x0008re Unknown
0x0009re Unknown
PBM - Parking Brake
U3000-16(20) Control module
U3000-17(20) Control module
U0401-00(20) Invalid data received from engine control module/powertrain control module
U0416-00(20) Invalid data received from vehicle dynamics control module
RBM - Running Board
U0416-68(2F) Invalid data received from vehicle dynamics control module
RCM - Airbag
U3003-62(AA) Battery voltage
RLM - Suspension
C1B18-62(AF) Supply voltage x-ref check
SASM - Steering Angle
C0051-62(2F) Steering wheel position sensor
SCME - DrivSeat Clim
B1154-98(28) Driver's seat backrest
B1156-7A(28) Driver's seat
TCCM - Transfer Case
U0126-87(28) Lost communication with steering angle sensor module
U0122-87(28) Lost communication with vehicle dynamics control module
U0101-87(28) Lost communication with transmission control module
TCM - Transmission
U0155-87(6D) Lost communication with instrument cluster control module
TPM - Tyre Pressure
C1A62-68(28) Rear right tire pressure sensor and transmitter assembly
C1A64-93(28) Spare wheel tire pressure sensor and transmitter assembly
U3002-81(2F) Vehicle identification number
VIM - Immobilizer
B1B01-87(2E) Key transponder
U0155-87(28) Lost communication with instrument cluster control module
U3003-62(28) Battery voltage
Bow down Bow down Bow down 2008 SC L322
2001 P38, Epsom Green, fully restored SOLD
Post #559073 26th Jun 2020 3:57am
GraemeS
For starters I would confirm that the new battery isn't a dud, perhaps by checking the voltage without the engine running then switch on the headlights to see if the voltage drops well away or only a little.
Post #559075 26th Jun 2020 4:38am
d00d
Battery good
12.2v w/the key off and when it's on the lghts are good and strong. Plus when it does/did crank that was still good and strong as well. (Forgot to mention engine would stumble occasionally starting with the old battery but has been fine with the new.) 2008 SC L322
Post #559076 26th Jun 2020 4:48am
GraemeS
Does you IIDTool not read codes with the ignition on but the engine not started? If it doesn't then I wonder if no power is getting to the ECM which usually powers the HS can-bus and being the same cause for the failure to continue running or not attempting to start. It seems as though it could be a basic power problem, possibly due to a loose fusible link in the engine bay fuse panel or a loose earth stud that is used by the ECM.
I have a wiring diagram for my MY12 TDV8 but there could be significant differences between MY07-09 and MY10-12.
Post #559084 26th Jun 2020 7:25am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
a similar issue happened to me
https://www.fullfatrr.com/forum/topic51475.html
Post #559091 26th Jun 2020 8:42am
Hi, Worth speaking to Pat at Gap, he should be able to help you to get the IID to work with just the ignition on...
Battery voltage under 12.4v is considered discharged, the voltage should be over 12.6v after the battery has settled following a charge...
I would start with the basics and remove and clean battery leads even if they look OK, then do the same for all the earths you can find...
Good luck and keep us posted... Pete
Post #559094 26th Jun 2020 9:17am
d00d
Oh, wow, that seems super-similar! Shocked And I didn't know about the CCF reset function in the IID tool, that could be extremely helpful! Thumbs Up 2008 SC L322
Post #559121 26th Jun 2020 12:58pm
d00d
Could just be user error, I'm going to check the power and read the manual before I bother him. Rolling with laughter
I know Rangies are voltage sensitive, didn't realize that much! Shocked (Guess I've always been lucky!) Will check voltage more properly today. Thumbs Up 2008 SC L322
Post #559123 26th Jun 2020 1:02pm
d00d
Current status
So it took a little longer, (busy, busy!), but we've got power at 12.6v and good grounds all the way around. We also discovered that once in awhile the CAN bus will work for a few minutes! And when it dies there's a burst of crap data on the line but we can't tell from what device.
Thud Anybody got a CAN bus troubleshooting flowchart or something like that? Even just knowing the bare minimum of which devices are required to operate would be a huge help! Bow down 2008 SC L322
Post #559860 2nd Jul 2020 12:39am
GraemeS
I had written that the TCCM was a HS can-bus gateway which it is for D3s & D4s but it is just another module in parallel on my MY12 L322. Hence I don't have any knowledge of your MY08 L322.
Post #559867 2nd Jul 2020 6:39am
GraemeS
Here's the HS diagram for MY10-12 in case its of any help.
https://www.fullfatrr.com/gallery/albums/u...0Speed.pdf
Post #559870 2nd Jul 2020 7:13am
d00d
Thanks Graeme, even if it's not a match it'll give me key words for searching! Laughing 2008 SC L322
Post #559958 2nd Jul 2020 3:42pm
d00d
Followup
After unplugging 10+ easy-to-reach devices on the CAN bus it's looking like the instrument cluster may be the culprit!
Will update once that's confirmed either way, but in the meantime does anybody know of a reliable cluster repair/rebuild service? Wink 2008 SC L322
Post #560534 7th Jul 2020 5:58pm
d00d
Cluster repair service in NA?
Cluster is definitely the cause of the CAN bus issues. After some reading it sounded like they could be reprogrammed so got a good unit off fleaBay only to find that the SuperCharged are apparently "special" and not reprogrammable. (Dealer said it was hit or miss, sadly this one was a miss.)
Stealer wants $1400 for a new unit!
Anybody know of a reliable instrument cluster repair service in America? Big Cry 2008 SC L322
Post #563740 6th Aug 2020 12:48am
d00d
Actual cause of this issue
Small addendum for those following along or finding this later. While it is true that the Instrument cluster was the cause of the CAN bus issues, the actual root cause was the ignition switch sending voltage spikes to the cluster and frying it. Apparently this is a rare problem but known to happen in this model series. 2008 SC L322
Post #574584 29th Nov 2020 11:06pm
