Home > Technical (L322) > Slow Water Leak |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
Hey everyone, does anyone have any ideas on where a small water leak might be on a 5.0SC. I basically am loosing about 300ml every 4 weeks / 1000 miles. No signs of a leak anywhere, no error codes so don't think its an internal issue, guess it could be rad as its had to see the whole thing.
25th Jun 2020 9:33am |
Water is normal anti freeze colour. I don't think there are any internal issues I think its just a small leak somewhere. |
25th Jun 2020 10:22am |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
I had the same issue and it turned out to be the water (coolant) pump leaking. |
25th Jun 2020 12:15pm |
Thanks, will go have a closer look at the water pump |
25th Jun 2020 1:26pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
I've had the same amount of water going missing, and then the top hose was cavitating when the engine cooled. I know mine is the 4.4 tdv8, different than yours, but I've just put a new expansion cap on and the hose is now ok and no water loss yet. Worth trying at Β£6 for the cap. |
25th Jun 2020 6:18pm |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 35 |
Hi Lighthouse.
25th Jun 2020 10:16pm |
Hey Pete
26th Jun 2020 10:26am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Mine is doing that as well. A camera showed it is the water pump and itβs leaking and leaving it in the V bottom. Still need to get it replaced π |
26th Jun 2020 4:11pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 472 |
I had a slight leak from my water pump on the old 4.4, intending to get it fixed. Then as I arrived at Meadowhall one day (80 miles from home) it went big style. Water was pouring out almost as quickly as I put it in.....
26th Jun 2020 6:03pm |
woodrjh Member Since: 13 Sep 2021 Location: Burgess Hill Posts: 26 |
So I've been chasing a coolant leak on my 2012 MY 5.0 S/C.
19th Jul 2022 1:17pm |
