Home > LPG > Any 4.2 or jag 4.4 owners with obd connected to lpg? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
IIRC the wire was just to cancel any faults every time you switched on, or off, either that or reset the fuel trims...
23rd Jun 2020 10:33pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Try running a fault scan when it next does it with the wire reconnected.
24th Jun 2020 7:48am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Haylands-
24th Jun 2020 8:02am |
Right, mine used to do that on occasion and all I'd do was the same as you switch off and restart would sort it 9 times out of ten.Sometimes it would take 2 shutdowns to get back to normal.
24th Jun 2020 8:09am |
Ps your diagnosis is probably a bit off too.
24th Jun 2020 8:22am |
dingg1 - two things - I changed the alternator etc recently and it made no difference although not done the water pump as not needed to.
24th Jun 2020 11:00am |
I didn't suggest that you needed to change the water pump or alternator, it just so happens that after that work was done on mine the issue has never came back.
24th Jun 2020 12:44pm |
ok but if I disconnect the gas from obd I have no issues? Current stable:
24th Jun 2020 3:45pm |
I never did disconnected the lpg system it still is tied into the wiring behind the obd socket |
24th Jun 2020 3:47pm |
Just to complete this thread someone else on here fixed it with an lpg ecu firmware update on an emer system but no other aeb ecus got said update.
21st Aug 2020 3:03pm |
