Home > Technical (L322) > Front drop links
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Front drop links
I realised today that when I disconnected my front drop links that there was no m12 restricted washer installed RYF000021. Mine are new (installed by others).
Should there be or has design changed? 2011 4.4tdv8 Vogue
Baltic Blue
Post #557925 16th Jun 2020 6:28pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Yes - lol Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #557953 16th Jun 2020 10:21pm
Gazcw
I have 2 new rear drop links still boxed. No washers there either. 2011 4.4tdv8 Vogue
Baltic Blue
Post #557957 16th Jun 2020 11:04pm
Pawl
I don't think they are considered a "consumable" item as they are very hard / difficult to damage, so the new links don't come with replacement washers.
I think they are probably needed because the steel the strut brackets are made of and low spec washers is pretty soft and would crush due to loads from tightening up the ARB nuts abd the high additional loads from the ARB when twisted a lot due to suspension articulation. Paul,
Post #557962 16th Jun 2020 11:43pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Over the winter I replaced everything suspension, both front and rear including all new nuts, bolts, and washers.
The most complicated thing when ordering all the parts was calculating just how many nuts, bolts, and washers also needed to be added onto the order at the same time.
I guess that some people don't bother to replace nuts, bolts, and washers. Sad L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #557976 17th Jun 2020 7:45am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Just swapped mine out and there weren’t any washers, either with the replacements or on the car Neutral
Post #576601 19th Dec 2020 3:45pm
