Home > Technical (L322) > Rumble/vibration at higher speeds - SORTED (pg2 post 7)
coopss
its an odd one - going in on Monday to be checked out but curiosity got the better of me..
Vibration worse 50+ and doesn’t go away, no matter the speed. I can feel it through the floor, seat and a bit through the wheel. It’s been slowly getting worse since it had a CV joint done at Keith Gott. I can now very faintly hear a soft rumble.
Any obvious clues? 10 points to the person who guesses correctly. Will report back once fixed.
Separately, the ride is really not good on bumpy roads - sometimes it feels like my old M3 with the edc on sport. 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #557486 12th Jun 2020 7:30pm
chugga90
Look at the heat shield for the rear prop/exhaust/fuel tank?
Cannot recall completely which part it shields?
However, previous user had got a lump of beech tree wedged up the one on my previous L322, this had folded part of it and was rubbing on the rear propshaft near the rear diff.
Made an odd vibration/noise, like a wheel bearing running rough.
Straightened out and reinforced repair patch fitted and noise gone!
Hopefully something simple like this?
Post #557514 13th Jun 2020 7:10am
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Wheel bearing. 2006 4.2 SC
Post #557518 13th Jun 2020 7:28am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Did the issue start after they changed the CV joint?
If so, then it may be a problem with the new joint.
Post #557524 13th Jun 2020 8:43am
coopss
They actually changed the gaitor not the joint.
May have imagined it but when turning right on the brow of a hill I’m sure I felt a juddering / skipping
Hopefully nothing too serious 1995 4.6 v8, green/tan (long gone)
Post #557638 14th Jun 2020 7:42am
stu1
Just to eliminate the CV joint - have you checked the gaitor is secure and properly fitted - if not, the grease will have come out and the joint may be getting damaged. I assume you had the gaitor replaced because it was split?
Another thing to check - open the drivers window and listen on a hard right turn from a stop with some power applied - any clicking noises from the front?
Post #557639 14th Jun 2020 7:53am
coopss
Yep had a split gaitor
Update from Gott: wheel balancing. Must have been way out... getting the box, diffs and tbox fluids done while it’s there. And the battery coded and denso start motor fitted. And side bars removed 1995 4.6 v8, green/tan (long gone)
Post #557836 15th Jun 2020 8:05pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Does it change if you steer left / right, if so look at wheel bearings, if it remains the same have a look at propshaft centre bearing. The centre bearing on mine started to fail, the first sign was a gentle ticking noise when slowing down, it started at around 30 mph, over the next 1000 miles it developed into a rumble from 50mph upwards and then got much, much worse. I had a new propshaft fitted by Green Oval and everything was good once again. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #557863 16th Jun 2020 5:32am
DrRob
It's been spoilt for sure up there Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557870 16th Jun 2020 7:17am
coopss
Got the car back - gearbox much smoother and car driving well
But not happy. Bastard vibration still there. They said it had been test driven twice before and after the wheel balancing and it was gone - it bloody well isn’t. Its so obvious through the floor and seats that once home this morning I could still feel it in my legs. Makes me question whether they drove it further than down the road and back, despite the paperwork showing “test for vibration 50-70mpg”
Keith Gott have let themselves down here. Going to try a more local non-specialist. Grumpy. 1995 4.6 v8, green/tan (long gone)
Post #557988 17th Jun 2020 9:44am
DrRob
Give them a second chance? Call and tell them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557999 17th Jun 2020 10:36am
coopss
Yep you’re absolutely right and I called them straight away. They asked me to take it back but at near enough a 2 hour round trip i won’t be soon. Will try the local person at suggested by joe90 1995 4.6 v8, green/tan (long gone)
Post #558003 17th Jun 2020 11:04am
DrRob
Fair point Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558005 17th Jun 2020 11:38am
coopss
Been back to Keith Gott who still can’t replicate it, and I can’t take the technician out due to distancing.
Can’t believe they can’t replicate it, it’s effing awful. They have said there is no play in anything underneath which points to the new tyres/brakes?
Their loaner D3 had exactly the same issue so they’re going to take it out and check 1995 4.6 v8, green/tan (long gone)
Post #560151 4th Jul 2020 5:04am
Fox889
Stupid question.....slight bulge in the tyre maybe?
Not sure what tyres you're running but could be a tyre starting to give way.......only a thought. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #560162 4th Jul 2020 8:18am
