Home > Technical (L322) > Help
v3mmtrangerover
United Kingdom 2008 Range Rover Vogue SE TDV8 Mariana Black
Help
So my RR 3.6 V8 is still at the garage 3 weeks now with thes faults
P0913-Fuel rail pressure to high input
P0191-Fuel rail pressure sensor range/performance
P117D-Fuel volume regulator control exceeding maximum control limit
P2290-Injector control pressure too low
The RR is at a land rover garage and he’s done loads of tests but apparently still no better off
When it’s sitting on the drive it will rev all the way up but when you take it for a run if you accelerate it goes bing bong engine fault lowers suspension limited gears etc can anyone help please
Post #557125 10th Jun 2020 6:10am
Maybe a blocked filter - some clues here - https://www.fullfatrr.com/forum/topic33222.html
Hopefully it's something as simple as this - https://www.fullfatrr.com/forum/topic50705.html?start=30
Post #557126 10th Jun 2020 6:38am
v3mmtrangerover
Tryed all that buddy still no joy
Post #557128 10th Jun 2020 6:44am
Could be what is either the pressure regulator or sensor on the HP pump.
Had similar on the D3, unfortunately on that the only solution was to change the HP pump as the broken bit couldn’t be swapped on its own. There is nothing that can't be fixed with a hammer😜😜
Post #557129 10th Jun 2020 6:54am
v3mmtrangerover
How can you test that?
Post #557137 10th Jun 2020 7:56am
Re: Help
[quote="v3mmtrangerover"]
Seems to me the common denominator for that lot is the Fuel rail pressure sensor, I take it you have tried that..?
What else have they tried..? Pete
Post #557139 10th Jun 2020 8:25am
As Pete says, what have they looked at
If you look in the WOrkshop manual it will point you to probable faults linked to the codes rather than relying on the generic description.
It does point towards fuel pressure/sensor problems.
Not sure how you would test that jndividually. The P117 would point towards the doobris on the fuel pump. There is nothing that can't be fixed with a hammer😜😜
Post #557152 10th Jun 2020 9:49am
v3mmtrangerover
Re: Help
[quote="Haylands"]
Yes I’ve bought a new sensor and had it read voltage and continuity tank pump in out shook it all about maf sensor turbo boost sensors abs sensors all cambus system
Post #557216 10th Jun 2020 5:16pm
Still thinking you need to look at the high pressure fuel pump. There is nothing that can't be fixed with a hammer😜😜
Post #557218 10th Jun 2020 5:27pm
v3mmtrangerover
It’s in the garage now so hopefully they suss it out sick
Post #557220 10th Jun 2020 5:31pm
v3mmtrangerover
so the Landy garage had it for 6 weeks injectors etc no joy I bought a used low mileage HP Pump fitted it in 1h and boom like a fecking train cheers for all the help gents Smile Smile Smile Smile Smile Smile Smile
Post #560950 11th Jul 2020 4:39am
mjdronfield
Nice one. Got there in the end.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #560971 11th Jul 2020 9:45am
Nick591
The landy garage must have been pretty useless! Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #561080 11th Jul 2020 10:07pm
