Home > Technical (L322) > Warm up at idle - or drive straight off? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
i let mine idle for 15 secs or so while i put my seatbelt on and check things like mirrors , climate etc...
9th Jun 2020 7:33am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
+1 Stan, by the time you figure out what radio station to listen to it's time to go.
9th Jun 2020 7:37am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
As you say, the general view is to just drive straight off, although as Stan quite rightly points out, there is generally a delay whilst you get settled and ready to start your journey. The 4.4 TDV8 doesn't need much effort to move down the road so I tend to just take it easy and don't race down the road trying to get up to speed as fast as possible. There's not a huge difference in rev's between idle and doing 30MPH so wear would be a minimum I'd guess. Although I have to say I have never known a vehicle with such a delicate DPF system. 2011 TDV8 Vogue SE |
9th Jun 2020 7:42am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I start. Check that there are no bongs or messages. Seatbelt on and then a very gentle drive until the engine temperature is rising and close to normal.
9th Jun 2020 7:46am |
btiratsoo Member Since: 12 May 2020 Location: Hampshire Posts: 174 |
I'm struggling to answer this.....on large marine engines, we have pre-lube pumps and jacket water heaters. For example the v16 Caterpillars in the boat I work on at the moment are kept at a steady 40 degrees Celsius and have a pre-lube pump that runs for about 1.5 minutes until the oil pressure in the engine is around 0.5 bar (7.5psi). This is to allow a good oil film to prevent wear on start up. The pre-heat is to keep the tolerances as they should be, so that the engine can be used without idling for too long.
9th Jun 2020 7:48am |
Correct, but one extra point here. The wear is worse on the initial couple of revolutions. The lube oil system is designed in such a way the the oil creates a film, but also a wedge as such. The oil being pumped into the space between the crank shaft and bearing for example, will physically lift the crank off the bearing surface. This is why we have "clearances" in plain bearings. The crankshaft is essentially running on the wedge of oil - if you want to get really scientific google "hydrodynamic lubrication". Acting on this principle then, points to the idea that as long as you have oil pressure, when cold and also warm, then wear should be reduced to a minimum regardless of the number of revolutions done. The downside to this is cylinder wear. The oil pressure doesnt have the same ability to hold the piston off the wall of the cylinder. In this case allowing an engine to warm up is much better, it will reduce the clearance between the piston and the liner, therefore reducing the amount of "slap" and allowing the piston to run on the thin film of oil on the liner wall - "hydrostatic lubrication'. It is a trade off really between the two issues. As with all engineering solutions there is a compromise to be had. Ben |
9th Jun 2020 7:57am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I agree with all above. I tend to wait until the idle drops, then drive off slowly & don't give it any beans until the engine is up to temperature. |
9th Jun 2020 8:15am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 537 |
Totally agree with the cooling down of turbo engines (I think failure to observe has seen the early demise of many turbos). I'm lucky, the last minute or so of my journey home is on nice level roads where it's not safe to exceed 20mph, which lets everything cool off nicely. Also agree with letting an engine get properly up to temp before using the performance. I've got an old BMW M3 and the manual is very specific about not using more than 4000rpm until the engine oil temp (they have a gauge) reaches at least 80 Deg C, I tend to keep below 3000rpm until it's nicely up to 90Deg C. Drives:
9th Jun 2020 8:36am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
I'm a bit "old school" in as much as letting the engine idle whilst you settle in, then driving off gently & keeping the revs down until its fully warm.
9th Jun 2020 9:01am |
Funny you say this Brian. An HGV driver friend of mine has just had exactly the same rant. He is like us, warm up/ cool downs. If you look after your vehicle it will look after you mentality. The clowns that run things who have never done the job are the problem. Anyway......we've digressed.
9th Jun 2020 9:07am |
I think it's mainly turbos that suffer in this extended oil change, no warm up/cool down age. Turbos run hot, it makes sense to let them warm through before expecting 90k rpm (or whatever) and then to let them cool off with oil flowing through them (also acting as a coolant) before shutting off and to change oil/filter at half the manufacturers advised periods. Drives:
9th Jun 2020 9:17am |
It doesn't take much to wreck a turbo! You're quite right there rvbush, warm up/ cool down is critical for turbos and regular oil changes. Think of the tolerances in the shaft and bearings of a small turbo on a TDV8. Its a failure point. |
9th Jun 2020 9:18am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
Mine idles while I go and shut the garage door/load anything in to the boot, and then there are several miles of 20mph limit before any higher revs. The reverse on return. I do believe in not booting engines before they have warmed up. This is reinforced by some BMW motorcycles which have TFT screen instruments: when the engine is cold the red line is at much lower revs on the virtual rev counter, it then moves up to the standard level once the engine is warm enough. A good idea that could be more widely adopted. Only Range Rovers since 1988 |
9th Jun 2020 10:32am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I just get in and drive off slowly and I also arrive home slowly 20mph on my housing estate. I was just wondering if any turbos will be spinning anyway. Geoff |
9th Jun 2020 11:51am |
