Home > Maintenance & Mods (L322) > Next time you're under the bonnet......
Fox889
apologies for the upside down photo's, no matter what I do, I can't get them the right way round! Embarassed Embarassed
Next time you have the bonnet up, check just above the side vents & below the windscreen side panel, both my 'foam thingys' weren't where they should be. One was tucked down near the door hinge & t'other was back about an inch.
I take it they're just meant to stop water & general debris going in towards the door hinge area?
Someone at JLR was obviously very low on UHU glue at the time, I've seen more glue on an envelope than on the back of both these foam wedges.
 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #557000 8th Jun 2020 10:13pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
They get soggy and most end up in the bin. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #557012 9th Jun 2020 6:54am
DrRob
Ditched mine on day 1. Water sodden traps. Made no difference to wind noise in car. A LR cheapy Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557017 9th Jun 2020 7:06am
Fox889
And there was me ready with the hot glue gun to put them back! Smile
You don't think they're worth putting back where they should be?
The one that was half way down the door, is indeed sodden, and needs to be dried first. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #557022 9th Jun 2020 7:30am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I'm sure they were originally put there for a purpose, perhaps to prevent water dripping onto the hinges as you mention but it seems that they were not fitted to last long. I have one still in situ and one that is loose, so far I have left them as they are (apart from putting the loose one back in place whenever I open the bonnet). From those that have taken them off, they haven't reported any issues so I guess you either re-attach or bin them, safe in the knowledge that whatever you do will be fine. 2011 TDV8 Vogue SE
Post #557028 9th Jun 2020 7:46am
