Home > Maintenance & Mods (L322) > Lower Tailgate Cable Disconnected |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8299 |
Pretty sure it's a captive nut...
6th Jun 2020 10:11pm |
Westminster Member Since: 23 Mar 2017 Location: UK Posts: 138 |
The strap has the bolt that should screw in the lower tailgate but there is nothing to screw into, just a hole. |
6th Jun 2020 10:55pm |
As I said, pretty sure it's a captive bolt which must have come off....
6th Jun 2020 11:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Load up a pic sir... |
7th Jun 2020 12:00am |
Yes I realised it was a captive nut but if it's sheered off it may require sorting at the garage rather than my just buying a replacement part, thought someone might know for sure that's all. I would post a picture but there really isn't much to see, just a hole! I'll ring LR parts tomorrow and see if they've got a diagram and can tell me. Thanks. |
7th Jun 2020 4:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35388 |
as Pete says, look at the other side and you'll see what's what.. ... - .- -.
7th Jun 2020 4:23pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1192 |
It`s called nut-set works like a pop-rivet. |
7th Jun 2020 4:45pm |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 |
Had the same problem when I replaced my tailgate straps - the nut came off on one side. If you remove the plastic trim along the top of the tailgate (the screws are fairly obvious) then you can get behind the carpet, find the nut rattling round inside the tailgate somewhere, then hold the nut in place while you screw the strap back in. |
7th Jun 2020 10:48pm |
Thanks that’s very helpful, hoped it would be something like this! |
8th Jun 2020 11:36am |
