Home > Technical (L405) > Fuse for boot 12v
Fuse for boot 12v
Any one know which fuse runs the boot 12v socket?
My boot socket isnt working. Are all the fuses in the 405 the stupid tiny ones which no one stocks? There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #556728 6th Jun 2020 8:44pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Luggage compartment fuse box, Fuse 18 (20A, yellow)
Either mini or micro type, you could swap it with fuse 17 (Middle accessory power socket)
https://www.ownerinfo.landrover.com/docume...c/G1797616
spare fuses of either type available from https://www.12voltplanet.co.uk/blade-fuses.html
Post #556751 7th Jun 2020 6:42am
Cheers
Will have a root about. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #556765 7th Jun 2020 10:51am
Turned out fuse 18 was Ok. The problem was between the seat and the steering wheel. I needed to RTFM and remember that the socket only works with the engine running......๐Ÿ™„
My bad, and in fairness to me I did actually know that somewhere in the noggin. Means you can plug a cool box in for a long journey and not have to worry about unplugging it if you stop For a couple of Hours, it was the same on the 322. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #556842 7th Jun 2020 6:26pm
