Home > In Car Electronics (L322) > Warning message !!
MikePearson
England 2008 Range Rover Vogue SE TDV8 Java Black
Warning message !!
Hi folks.
I've recently bought a 2008 TDV8 Vogue SE and the Message Centre display is briefly showing "AV OFF" when ignition key is first turned to P 1 or 2.
It goes off once started.
Any ideas please?
MikeP
Post #556668 6th Jun 2020 3:10pm
Classic888
Normal as far as I know, mine does it all the time. I may be corrected of course and mine may have a fault also!
Post #556670 6th Jun 2020 3:18pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I assume you have the radio switched off? In which case it's normal.
Post #556671 6th Jun 2020 3:29pm
MikePearson
Thanks guys. New to these things as an owner. Will try it with leaving the radio on at lockdown. Many Thanks.
Post #556679 6th Jun 2020 3:45pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
The same message flashes up when I start my 2005 TD6.
Nothing to worry about buddy 👍
Jim
Post #556681 6th Jun 2020 4:25pm
