Home > General > Diesel Reliabilty - BMW vs Ford - Summary |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7806 |
It’s the BMW Petrol V8s that had a porous issue. The TD6 engine is arguably the most reliable engine ever fitted to an RR, but as you say, the gearbox is very much a weak point, the valve body being made from softer aluminium......
5th Jun 2020 1:17pm |
https://www.fullfatrr.com/forum/topic49491...=3+6+turbo
5th Jun 2020 1:24pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
I had an X5 with the same TD6 engine for 5 years, couldn't fault the car nor the mechanics, the straight six was a gorgeous old lump, super reliable & I had mine chipped which gave her a little more 'get up & go' but to compare a TD6 to any variant of the TDV8 is 'chalk & cheese'.
5th Jun 2020 2:22pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
They all have problems (as every car or manufacturers do), all cars can and do lunch a engine or gearbox, it’s a lottery so get what the pocket can afford and best suits your needs.... newer, lower miles should mean less issues in general but again no guarantees.
5th Jun 2020 3:16pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
You asked about diesel reliability, there is only one answer: TD6. .
5th Jun 2020 3:18pm |
What I have found is cars in general get neglected by the vast majority of owners and this gets worse once out of warranty and service plans, this accelerators the feeling of unreliability seen on the web and down the pub.
5th Jun 2020 3:23pm |
JackNorris Member Since: 24 May 2020 Location: Bedfordshire Posts: 8 |
Thanks all.
5th Jun 2020 3:24pm |
Looking at your response I would suggest a well looked after TD6 might be the answer.
5th Jun 2020 4:37pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3749 |
If you want an unbiased opinion and having owned all of them the L322 TD6 is a fantastic reliable and solid unit - the weak point is the gearbox. All round the TDV8 is the best as it’s packaged with the 8 speed gearbox. If the budget is TD6 - then it’s a bloody good engine, I had mine remapped by JE and it went like stink, and didn’t have any gearbox or any other issues - my comments on gbox are based purely on what other users have reported - mine was absolutely faultless over 4 years of motoring and towing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
5th Jun 2020 8:26pm |
It was JE who remapped my TD6.
5th Jun 2020 8:49pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
I've had two Td6's, they are a great engine, and i travelled many miles in them towing a twin axle caravan too with no issues. But the move to the TDV8 was was a huge jump in both power and refinement. I had the TDV8 5 years and covered over 70k miles in it, it had done over 160k when I sold it, the only issues I had was alternator and turbo hoses neither of which left me stranded, it was a great reliable car. I did service it well with regular oil changes on both engine and transmission. Also important to look after the turbos, let them cool down and spool down before switching off. Good luck with your searching |
5th Jun 2020 9:52pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
I basically agree with the above post
6th Jun 2020 2:45pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I run a TD6 and like the fact that it is in the low band road tax bracket, is cheap to insure and easier (compared to a TDV8) to work on. TD6’s are almost at their rock bottom prices now so there is no worry about depreciation.
6th Jun 2020 4:18pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Morning all - interesting post this as I was about to ask similar questions . . .
7th Jun 2020 12:42pm |
