Home > Maintenance & Mods (L322) > P040D-00 (2C) restricted performance |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Hi Andy, assume you have seen my guide.
4th Jun 2020 11:39am |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 |
Hi Greg,
4th Jun 2020 11:49am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Have you checked all 4 donut hoses and the throttle chamber intake one?
4th Jun 2020 1:34pm |
hiya,
4th Jun 2020 2:13pm |
Good it didn't trigger again today Andy...
4th Jun 2020 2:28pm |
Thanks for the ideas so far guys, really appreciate it.
4th Jun 2020 2:36pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Andy, when you read faults put the tool in advance mode and see whath it reads. 2012 TDV8 Black Edition
4th Jun 2020 3:54pm |
Andy - has your motor had the CSOV fix? There is a TSB on here that explains it all. You can see down from right hand side of radiator with a torch if you know what you’re looking for.
4th Jun 2020 4:44pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
When the CSOV is stuck it throws up restricted performance as soon as you hit 2500 rpm. It also has a very obvious fault code description.
4th Jun 2020 5:02pm |
Hi Mike.
4th Jun 2020 6:26pm |
I took me a while to find the valve but with an LED torch focussed into a spot I found it after about 5 mins looking.
4th Jun 2020 7:42pm |
OK a bit of an update..
5th Jun 2020 4:11pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
yup. Fuel in oil contamination. you need to check the level of fuel in oil. Ideally do an oil change asap.
5th Jun 2020 6:52pm |
Thanks for that. I’ve a smoke test booked for Tuesday first thing. Will get them to do an oil change as well. 2011 4.4 TDV8
5th Jun 2020 7:42pm |
