Home > Technical (L322) > Possible BCM replacement
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
One of the earlier post asked if my steering wheel was straight. Well the answer was no, then someone said have you had the tracking done well here are the results.
Before
After
Hopfully that will correct the fault fingers crossed
Post #556457 4th Jun 2020 11:25am
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
With those voltages and battery issues a very cheap thing to try, add an additional earth strap to the engine, can fit one between earth stud on passenger side wing to the closest inlet manifold stud to front of car.
See if that fixes some of the power issues, esecially the 12.6v while running. A bad earth can throw up a lot of codes and cause random starting / charging issues and its a very cheap / easy thing to check.
Post #556480 4th Jun 2020 1:39pm
matlandy
It turns out I might have fixed the fault I've been driving around for a week and the lights have stayed off, so it turns out it was just the tracking
Post #557970 17th Jun 2020 8:01am
Not so much the tracking, it's the poor little confused SAS that thought you were turning when you weren't...
Glad you got to the bottom of it... Thumbs Up Pete
Post #557975 17th Jun 2020 8:44am
