![]() | Home > Maintenance & Mods (L322) > Squeak when I turn left |
vikehp Member Since: 30 Apr 2020 Location: Deauville Posts: 5 ![]() ![]() ![]() |
Hi everyone,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
lower suspension arm? ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
What Stan said and A few things to check, wheel bearing, they can squeal when in the early stage of failing... disc stone shield is bent and touches when turning, this is a common fault... brake pads can do it as well if the caliper is sticking... drive shaft CV joint can do it as well, check the boot to see if it's split...
Thank you for your feedback |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Anti squeal shims in the calipers with the pads? coat the rear face of the pad and the shim with copper grease or ceramic grease to stick them together. BMW i3 Electric Car
I had a very similar thing occurred on my TDV8, I think it was as the caliper warmed up, clearances changed and squeal started. Many moons ago my dad had a Morris Marina that did it terribly and it took while to discorver copper grease on the back of the pad solved the problem. BMW i3 Electric Car
Let's hope that the copper grease was the beginning of a solution 2011 Range Rover Vogue 4.4 TDV8 |
Do not use copperslip on yours, you have aluminium calipers and it is not good for them, use the correct aluminium grease.. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I use ceratec on my pads. Either Pagid or Textsr do it. Always seems to work ok. There is nothing that can't be fixed with a hammer😜😜
Thanks |
