Home > Technical (L405) > Rear Brakes. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 |
Need to do mine soon, so have probably read the same as you. I don’t think they need calibration just the following, happy to be corrected if anyone knows better.
31st May 2020 9:47pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
To answer both questions, we have the correct diagnostic tool so always use that to put the vehicles into and out of service mode but i see no reason why the procedure above wouldn't work... If you do NOT do the job correctly (placing vehicle into correct service mode) then you will brake the calliper internally! The piston just pushes back, we use a brake pushing tool but i guess anyway you can push the piston will work oh and yes, the emergency/hand brake is the calliper not in an internal drum sir... |
31st May 2020 10:43pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 |
Cheers Craig and Dave
1st Jun 2020 3:53pm |
Thanks Craig, I have just bought a diagnostic tool which says it will do the Parking brake service, so i will be trying it out when the time comes, if all else fails its back to the handbrake button and cycle the ignition switch |
1st Jun 2020 4:31pm |
Which one did you get Dave? There is nothing that can't be fixed with a hammer😜😜
1st Jun 2020 4:39pm |
Got the Autel MD 806 Pro. Very impressed up to now, had an airbag light on which it steered me straight to, (wiring fault behind the drivers airbag).I've only used it the once but it does do a full system scan which is useful, and displays live data so you can watch whats going on with intermittent faults. I'll post more as I get to use it more, not too often on mine though I hope |
1st Jun 2020 4:49pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
Sub’d 2014 FF Autobiography 5.0 SC
1st Jun 2020 7:46pm |
LR discs have arrived from Duckworth parts.
9th Jun 2020 3:20pm |
Check how much free room you have where the front pads fit NMJ... The 6pot callipers have a tendency to expand somewhat and clamp the front pads! |
9th Jun 2020 11:11pm |
they went in nicely. Although I made the same mistake as last time and don’t order a wear sensor...will have to pop to the LR parts desk later and get one as it wouldn’t come out without snapping..
10th Jun 2020 6:43am |
