Home > Wheels & Tyres > Replacement Locking Wheel Nut |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
It should tell you what type it is on the socket you use to remove it. I think that the early ones are marked A, B, C, D & E
30th May 2020 6:52pm |
To be honest most folk on the forum, myself included, remove the locking wheel nuts due to the chan e of them failing and then having to be cut off.
30th May 2020 6:55pm |
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 |
I've just got rid of my locking wheel nuts and replaced them with normal ones. 2017 SDV8 Autobiography |
30th May 2020 8:01pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1537 |
Yep, I got rid of the locking nuts, too. Ron B. VK2OTC
31st May 2020 2:55am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Ditch all locking nuts
31st May 2020 6:22am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2660 |
Yup, had to get a specialist to remove mine , they are awful , took them off. |
31st May 2020 7:18am |
sgreenham Member Since: 21 May 2020 Location: Southampton Posts: 11 |
Thanks for all the replies guys. Why are they so bad on a Range Rover? Never had any issue before with locking wheel nuts? |
31st May 2020 4:04pm |
The locking nut is a 2 part design. Sometimes, particularly on older car with original locking wheel nuts, the top part with the notches detaches from the bottom solid part. This results in the top part just spinning and you then have to cut the locking wheel nut off.
31st May 2020 6:37pm |
Same on Disco 3 and 4 and Sports. Same design of nut Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
31st May 2020 7:11pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
The tyre shop I use warned that if the locking nuts are overtightened they can be a real problem to get off, easily done with air tools etc. They recommend only hand tools be used, saying that the air tools are also a contributor to the nuts swelling, on the basis that they blow damp air under the nuts. Anyway, I've removed the locking nuts on the last two RRs and just have standard ones. I'm not one for jet washing or chemical cleaners when the wheels are on the car either. Only Range Rovers since 1988 |
31st May 2020 8:19pm |
Replace your nuts every year Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
31st May 2020 8:55pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Is there a metallurgic reason LR don't use solid stainless?
31st May 2020 9:07pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7958 |
It's impact guns that knacker the nuts - they rattle them loose.
1st Jun 2020 5:45am |
When I asked the dealer foreman about solid stainless nuts he advised against, saying stainless would be worse for galvanic corrosion. That seemed counter-intuitive to me so I searched online, and there was some evidence from the US construction industry to support it.
1st Jun 2020 10:37am |
