Home > Technical (L322) > 2004 Rear Brake Calipers |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
That looks suspiciously like a front one...!!
31st May 2020 10:42am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8507 |
Try a local motor factor, they are generally a generic calliper so will probably be on the shelf. don’t be scared off a refurb unit. They are normally as good as new. I’ve had a few from factors and they look like new. There is nothing that can't be fixed with a hammer😜😜
31st May 2020 10:51am |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
Pete - Looks like you may be right! It's definately stamped with AF's rear brake code, so suspect there's been a screw up somewhere along the line. Might take the opportunity to do the front ones as well then....
31st May 2020 11:17am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
They'll be wanting them sorted as the front ones will be much more money than the rears you paid for... |
31st May 2020 10:58pm |
All sorted, mix up on the website. Big thanks to Paul at AF for getting the right ones out overnight.
2nd Jun 2020 8:07pm |
2nd Jun 2020 8:45pm |
