Home > In Car Electronics (L322) > Low cost digital tv upgrade
Page 3 of 4 <1234>
Andy
Yes, but I want tv in motion as well. I don't think that has that facility by the looks of it. The two leads I have, have a box halfway down the loom. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #53367 7th Mar 2011 4:16pm
ahh sorry mate ..what about a bmw unit ,should be compatible with the range.. ... - .- -.
Post #53370 7th Mar 2011 4:29pm
M44K TS
I tried a TV in motion cable in mine and it didn't work, in the end I bought the nav coder interface and it worked perfect after that. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #53386 7th Mar 2011 6:13pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Well I'm with you 100% on the cheaper Thumbs Up
Noddy , only disadvantage I see with that one is that it doesn't look to have an obvious plug in sensor for the remote. If you got one with this feature.. you don't even need to run it to the front ... run it ip to the top of the D pillar trim and just point the remote rearwards when using.
I like the idea of music and vid on the usb / sd card. Dunner even need the ipod then! I'll browse the other linked ones now... I've had this on the ideas shelf for a while.
You can always keep the reverse camera as well... just have a 2 into 1 cable adapter for the AV inputs.. then relays to shut the TV power off / TV feed off in reverse. If relays and such ain't your thing a simple switch arangement could quickly be cobbled up for the centre console. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #54998 16th Mar 2011 12:01pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Ajay(UK) wrote:
That depends on an indivduals definition of "Low Cost" Rolling Eyes
I bought my BMW Hybrid TV Tuner for £320 and sold my old LR analogue tuner for £250 and if my maths are correct thats a very nice "low cost" of £75 Whistle
It's all a question of timing Wink
In this instance, your maths are incorrect, it cost you only £70 (unless you have added hidden costs of £5). Sorry, had to mention it! Very Happy Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #55528 18th Mar 2011 10:40pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Embarassed Surprised noone else picked up on that Laughing Because of the "if my maths are correct" I had to edit it Rolling Eyes 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #55538 18th Mar 2011 11:07pm
RRVSE
Embarassed Surprised noone else picked up on that Laughing Because of the "if my maths are correct" I had to edit it Rolling Eyes[/quote]
You might as well , I would have!! Smile Smile Steve
Post #57494 29th Mar 2011 11:52pm
Andy
I managed to get one of these leads and have tried it today. I bought the Freeview unit mentioned on page one of this thread.
I plugged the DVB-T unit in using the video and audio in cables. Switched TV to AV and .... nothing. Sad
The unit is powering up and the remote powers it on and off but I'm not getting any image or menu. The instructions are OK but don't mention anything about any pre-power up operation or inputting of any codes etc
Back to the drawing board! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #69151 18th Jun 2011 1:41pm
Reformed
I have done this on mine and the only thing I changed was the ariel that came with the unit. I changed it for an amplified version from ebay and it works well.
Are all your connections tight and have you definately got your AV leads plugged into the correct AV inputs on the lead?
I just turn my TV on, select AV and turn the freeview box on.
Mine has a DVD system allready in with screens in the headrests so I just split the DVD input to take both DVD and freeview.
I did have the tv in motion adapter lead but I have now sold that on and used navcoder to enable it. Reformed
Post #69159 18th Jun 2011 3:40pm
Andy
Everything is connected as it should be, yes.
Thing is, I'm not sure whether it's the lead or the freeview box that's at fault. Both have 12 months warranty so that's not an issue. It's just determining which is/isn't working.
I can't even think of anything else I have to hand that I could plug into the loom to test it 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #69182 18th Jun 2011 6:57pm
Reformed
It could possibly be the freeview box, the first one I brought did not work so I returned it & got my money back, and then I brought one like the one mentioned at the start of this thread and that worked (apart from the signal) so I brought the cheap £20 amplified ariel of ebay and wired that up instead, and mine has worked fine ever since.
I would contact the seller and try a replacement.
Another easy check, is if you have something like a portable dvd player or camera that connects to the TV, try and connect that to your lead on the car and see if the AV channel picks that up, if it does then you know its not the lead. (Infact when I was testing mine, I put an extension lead out to the car and plugged in the DVD player from upstairs, and used the AV outputs into the car loom and that worked, thats how I found out my first freeview box was not working, at the time I managed to lose my incar DVD system as well but that was my fault as I had left it unplugged!!) Reformed
Post #69183 18th Jun 2011 7:18pm
Andy
I'll try that -thanks for the help! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #69290 19th Jun 2011 10:27pm
p38arover
Australia
I changed my 2004 L322 (BMW non-touch screen) to digital TV yesterday. And one gets digital radio channels too - but it's mono.
I bought the PIBUS PTV kit from Melbourne and a digital TV tuner from China. See PTV - Digital TV interface board for BMW
Don't buy the PTV board from the same bloke in China who sells the DTV - he's ripping off the Aussie who designed the unit.
The hardest part was drilling two holes for the antenna connectors and two holes to fit the USB socket (for playing movies from a USB stick). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #447584 12th Aug 2017 9:47am
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I tried to buy the Aussie board but it says out of stock and when I emailed him to ask when they would. E available the email was returned undelivered?
Post #450949 14th Sep 2017 9:44pm
p38arover
Australia
I'll drop a line to Peter to let him know.
Re the PTV board, I'll also check if China is still buying from him. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #450952 14th Sep 2017 10:18pm
Page 3 of 4 <1234>
