Home > Technical (L322) > Tow bar Eletrical options |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Remove your current loom set up.
24th May 2020 7:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8507 |
Yep, get a 13 pin socket fitted. Should just be a unscrew and refit. Have a look at the PF Jones option. Should be pretty much identical to the LR one.
24th May 2020 7:46pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Thank you.
24th May 2020 7:55pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Personally, I would simply replace the existing 7-pin as you just want a trailer board & do not require the caravan facilities.
24th May 2020 7:56pm |
Thanks for the reply buddy.
24th May 2020 9:23pm |
The black topped socket is mostly lights, the white topped socket is the 7S socket. This powers the the auxiliary systems in a caravan such as the fridge.
24th May 2020 9:53pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
A bit of help, I hope
24th May 2020 9:54pm |
Thanks guys.
24th May 2020 10:10pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
We've got a 13 pin towing socket on our 2012 AB. The 13 pin electric towing socket has a permanent 12v feed that is connected directly to the battery for powering a caravan so the charger is connected straight to the battery. In 8 years our car has covered 23k miles so it spends an awful lot of time in the garage with this plugged in. We use a C-Tek smart charger (MXS-7.0) which we've used since it was a year old and haven't had any problems. I'm a firm believer that it works as our car is still on it's original battery too. The adapters to do it are in the club shop: https://www.disco3.co.uk/shop/tow-electric...c-p45.html For this reason alone, I'd only fit a genuine 13 pin towing socket on one these days. It's very handy and is straight forward to fit. Take the spare wheel out for a bit more room, unscrew the socket, follow the loom through the spare wheel well unclipping it as you go and unplug it from behind the trim panel on the drivers side in the boot then pull it out from the bottom. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2007 Range Rover Supercharged in Java Black with Ivory Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior |
25th May 2020 12:18pm |
I'll go with David on this.
25th May 2020 1:30pm |
I’ve ordered the pf Jones 13 pin plug and loom as a direct fit so I can replace the twin for this.
25th May 2020 1:47pm |
[[/quote]
25th May 2020 2:08pm |
You will need an adaptor as 7pin plugs do not fit 13pin sockets. (see my previous post regarding adaptors). 2003 Range Rover Vogue TD6 |
25th May 2020 2:10pm |
https://www.towsure.com/towbar-electrics-a...gK20PD_BwE
25th May 2020 5:48pm |
